04-23-2021 03:54 - last edited on 04-26-2021 20:17 by LiliyaFitbit
Versa lite screen is not working. No image. I've tried restating and charging and there is not image just a blank screen.
To check its actually charged. Can you sync with the phone? If so the battery is not flat,
Are you able to restart it with the button?
If it doesn't work probably best to contact Fitbit Support directly. They may be able to help you.
