12-12-2019 12:23 - edited 04-27-2020 11:08
Fitbit Update: 4/27
Hi, Versa Lite Fam!
Today we're announcing a new firmware: Fitbit OS 4.1.2(version:70.7.27), which addresses and solves the firmware update issue that was identified and reported in this thread. Please update to this new firmware once you see the update banner inside of the Fitbit app.
If you attempt this new update and have issues, PLEASE FOLLOW these step by step instructions in this article: Why can't I update my Fitbit device?
DO NOT ever attempt a factory reset as a troubleshooting method for Versa Lite. Thank you all for your patience while a fix was put in place.
Fitbit Update: 12/12
Hi Versa Lite users,
If you recently purchased a Versa Lite, or if you recently tried completing a firmware update and had issues our teams are aware of the problem.
We're currently investigating and working on a resolution. Please DO NOT perform a factory reset on the watch as a troubleshooting method.
Instead, try the following:
As a side note, if you encounter any issues while updating it, please perform the troubleshooting mentioned in this article: Why can't I update my Fitbit device?
Thanks for your understanding and cooperation while we work hard on a fix.
Best Answer02-17-2020 11:58
02-17-2020 11:58
02-17-2020 15:29
02-17-2020 15:29
@SunsetRunner what are these references to a win 10 referring to?
I can't think of anything with the Versa lite that can not be done through a phone.
Best Answer02-17-2020 17:54
02-17-2020 17:54
If you brick your Versa Lite, you'll need a Windows 10 laptop to re-install the firmware.
Best Answer02-17-2020 18:53 - last edited on 03-09-2020 16:03 by LiliyaFitbit
I have 2 that are bricked because ssd's support told e to do a factory reset even though the website told me not to. I dont have win10.
Moderator edit: format
Best Answer02-17-2020 18:57
02-17-2020 18:57
Find a friend, sibling, etc. who has one and you can fix your Versa Lite. It requires a Windows 10 laptop. Basically, it involves stopping Fitbit on your phone, then set up the Fitbit app on my Win 10 laptop.. After that you connect the USB charger to the USB port on my laptop. Use laptop Bluetooth to pair Fitbit with the Win 10 laptop. and then start the update from within the WINDOWS 10 app (not the phone app).
Best Answer02-17-2020 20:43
02-17-2020 20:43
Does it also work with MacBook?
Best Answer02-17-2020 20:54
02-17-2020 20:54
Best Answer02-18-2020 00:02 - edited 02-18-2020 00:03
The Versa light can not communicate through the USB cable. The only thing a user can do is by plugging in the charging cable is to charge, restart, or factory reset the tracker. This can be done with any power source.
If support asked you to restart the device, and it hasn't powered on, then support should be responsible.
Best Answer02-18-2020 14:40
02-18-2020 14:40
Best Answer02-18-2020 20:40
02-18-2020 20:40
Best Answer02-20-2020 01:12
02-20-2020 01:12
My fitbit Versa - Not Lite Edition has frozen since I was asked to update my software. This is over 12 hours ago. I have tried plugging it in to the computer and it was in Wi Fi and charging when I attempted the update. It is now frozen on the Fitbit Logo - Help me please. I use my Versa everyday.
Best Answer02-20-2020 06:49
02-20-2020 06:49
Oh no mine have been updating for over an hour. I use my all the time sorry it did up date
Best Answer02-20-2020 07:05
02-20-2020 07:05
They monitor the forum but never offer help or answer questions. Bad service.
Best Answer02-20-2020 07:45
02-20-2020 07:45
I was so happy to have the watch working I didn’t realize the firmware wasn’t updated till the next day. I was planning on borrowing the same Win10 laptop to do the firmware but you’re saying the firmware still isn’t going to take? Did you try and have to reset it again? I’m not going to ask the favor of borrowing the laptop if it is a waste of time. Thanks in advance for the advice.
Best Answer02-21-2020 18:52
02-21-2020 18:52
hi so my versa lite actually finished its firmware update however the fitbit would reset on its own and it has been on a loop. I’ve restarted my phone and its still happening. What do i do?
Best Answer02-21-2020 20:45
02-21-2020 20:45
Best Answer02-23-2020 00:06
02-23-2020 00:06
Best Answer02-23-2020 03:53
02-23-2020 03:53
Best Answer02-23-2020 05:09 - last edited on 03-09-2020 16:04 by LiliyaFitbit
What is it about factory resets that is so bad? I reset mine at least 3 times and never had an issue with it. Also mine is working now.
Best Answer02-23-2020 05:14
02-23-2020 05:14
after the resets both have a red X and say data not synced. No matter what I try it will do nothing.
