11-21-2024
10:41
13:46
ManuFitbit
11-21-2024
10:41
13:46
ManuFitbit
My fitbit versa lite will not keep the correct time.
Moderator edit: clarified subject.
Best Answer11-21-2024 12:49
11-21-2024 12:49
Hi @Fitz01. Welcome to the forums.
Thank you for providing the details about this difficulty with your Versa Lite.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with.
If you've tried the above but to no avail, make sure you're not running into syncing issues. For more information, see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Versa is syncing, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again. See: How do I change the time on my Fitbit device?
Best Answer11-21-2024 19:18
11-21-2024 19:18
Best Answer11-27-2024 14:27
11-27-2024 14:27
Thanks for responding @Fitz01.
Sorry to know tha you are still experiencing the issue with the time in your device.
Since you tried the steps and they didnt work, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done.
