07-26-2021
13:42
18:42
LizzyFitbit
07-26-2021
13:42
18:42
LizzyFitbit
what a bunch of bs. can someone answer a direct question
Moderator Edit: Clarified subject and updated label
Best Answer07-26-2021 13:54
08-01-2021
18:49
08:54
08-01-2021
18:49
08:54
Hi @rosswood. Welcome to the Community. @Odyssey13 Thanks for stopping by to help our members.
@rosswood I've moved your post to the Other Versa Smartwatches board as there are more chances to get related replies here. I'm sorry for the difficulties you're experiencing with your watch and to help you out, may I know what is your question? If the issue is with your watch not syncing, may I know the model of your phone? Also, do you see an error message on the Fitbit app when trying to sync?
Because your post didn't mention, I'd recommend trying the troubleshooting steps described in this help article to get your watch syncing correctly.
Hope this helps.
08-03-2021 19:34 - last edited on 08-04-2021 15:44 by LiliyaFitbit
Hi, 1) fitbit versa light no longer syncing since 22jul; no error msg. rcd.
Thx.
Update:
trying to continue syncing to windows 10; have tried turning on/off btooth
Moderator edit: merged replies
08-08-2021
15:32
08:55
08-08-2021
15:32
08:55
Hi @rosswood. It's good to see you again.
Thanks for letting me know that your Versa Lite isn't syncing, as well as trying some steps on your own. I understand how you're feeling about this situation and to work on this together, may I know if you've also tried the suggestions described in this help article? If you have, let me recommend these other steps to reconnect your watch to your account:
Hope this helps.
