10-10-2020 08:09
10-10-2020 08:09
Recently my Fitbit versa lite is tracking my pace at about double. e.g. saying that I'm doing 29' miles when I'm actually doing 15' miles on my walk. Hence it's also not counting all my steps. I compared to using Strava, both which use GPS.. How do I fix this?
Best Answer10-10-2020 18:46 - edited 10-10-2020 18:48
I'm not sure how to fix, steps are counted not with GPS but by looking at the arm motion.
Pace is determined by distance. You did not say if the distance recorded is correct. Is your stride correctly set?
Are you using the GPS with the Fitbit recorded walk?
Have you done a step count test? Take a walk while counting your steps then compare to what the Fitbit says.
Best Answer10-10-2020 20:04
10-10-2020 20:04
10-10-2020 20:04
The distance is registering about half as well. Even the same route as last week might register half of what it did last week and half of what the Strava app is.
Best Answer10-11-2020 13:53
10-11-2020 13:53
Ok but where you using the GPS?
Is Strava connected to fitbit?
Best Answer10-12-2020 05:45
10-12-2020 05:45
Best Answer10-15-2020 05:40
10-15-2020 05:40
Did you try adjusting the stride length? Maybe that may help.
Best Answer10-15-2020 06:31
10-15-2020 06:31
