08-06-2020
03:43
12:09
DavideFitbit
08-06-2020
03:43
12:09
DavideFitbit
my versa lite is dead, it will not come on at all it will get to the fit bit logo and then it say ; data not cleared sync again but it will not do anything, it will not charge, screen is black. what can I do?
Best Answer08-09-2020 08:02
08-09-2020 08:02
Hi @FT72 several have reported that a factory reset has helped here. Did you do a search?
If not you will need to contack support.
