03-19-2020 19:27
03-19-2020 19:27
I am so frustrated with my Versa Lite. It kept restarting itself a couple times an hour so after looking online I did a factory reset and am trying to add the device back, but when it starts adding I get to about 13% and it stops. The device will even show up on the app still and say there’s a new update so I tried that and still it gets to 13% and fails. How do I fix this?
Best Answer03-24-2020 11:37
03-24-2020 11:37
@Kyla16 You can set up the device using your computer. Please take a look at this article.
To factory reset using the back button:
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Best Answer03-20-2020 17:55
03-20-2020 17:55
@Kyla16 Have you tried rebooting Versa and your phone, putting Versa in the charging dock, and restarting the whole process? If this does not help, you might want to try:
Best Answer03-24-2020 09:40
03-24-2020 09:40
@Kyla16 did you manage to make it work?
Best Answer03-24-2020 10:56
03-24-2020 10:56
Thank you for the reply. I tried deleting the app and the device from the app and starting from scratch, but that has gotten me nowhere. I can’t factory reset again because my Fitbit just flashes the start up screen.
and unfortunately I don’t have another device that I can download the app onto to try that 😡
03-24-2020 11:37
Best Answer03-26-2020 16:14
03-26-2020 16:14
Thank you for the suggestion. I tried setting up my Fitbit on a tablet and that failed as well. I’ll have to give customer service a call one of these days and hopefully they can help
