Versa Lite showing Data not cleared
I did what the instructions say to do to erase data on the fit bit versa lite. After a minute, the screen states Data not cleared, Sync and try again. What do I do now? It wil . It do ANYTHING at all a d wont sync bc device says not found when I try to sync it.
1 REPLY 1
@CarieBear Welcome to the Community. Sorry for the delayed reply.
Thanks for the details mentioned and the troubleshooting tried. I would like you to restart your watch and check if after this your watch shows the main screen.
I'll be around if you have any additional questions.
