06-18-2021
08:03
15:21
YojanaFitbit
06-18-2021
08:03
15:21
YojanaFitbit
My versa lite won't sync. Nothing happens when I click the sync now in the app and there is a message that says data not cleared sync and try again. I have tried unpairing and pairing with my blue tooth and restarting my phone multiple times.
15:22
04:38
06-26-2021
15:22
04:38
Hi there, @Kimberly10. Welcome to the Community Forums. Thank you for sharing the steps that you've tried to fix the issues with your Versa Lite.
Please note that the error message you're now receiving on your watch's screen ("Data not cleared, Sync & Try and again") usually appears when you've performed a factory reset without first unpairing the watch. With that being said, please try the steps below:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
