08-13-2020
11:38
09:26
08-13-2020
11:38
09:26
Hi my versa lire, purchased in January, has been very sluggish lately, slow to sync and respond to screen tapping. Anyway this evening it got stuck on exercise mode and I did a restart. Then it was stuck on home screen so I tried to do a factory reset but when I pressed the side button there were yellow lines on the screen and now it is unresponsive. What can I do now? Do I need to return it to get it fixed as it’s under warranty or is there anything else I can do to try and fix it. I had only just charged it to 100% earlier today as the battery had died this morning at some stage.
Hi there @Kittymac, welcome to the Community Forums. I'm sorry to hear about your Versa Lite's recent behavior. Thanks for the details provided in your post and for your efforts in trying to fix your watch, I'll be glad to continue assisting you.
In order for me to better assist you with this, please confirm that you've followed the steps below:
If the suggestions don't work, I'd like to know if your watch vibrates when you connect it to the charger? If not, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
