12-09-2020
05:24
15:32
RicardoFitbit
12-09-2020
05:24
15:32
RicardoFitbit
Good morning! My Versa Lite stoos working in the middle of a workout. It just started doing this. What is wrong it?! I mean I know more than 61 calories has been burned after a HIIT workout for an hour! I can stop and look at the fitbit and it will be gray unless I tap the screen🤔 Solutions?!
Moderator Edit: Formatting
Moderator Edit: Label
Hi @Bluebelt, welcome to the Community Forums.
Thanks for bringing this to our attention and for the details that were shared. To better assist you with this, can you please elaborate on your Versa Lite issue? In which way it's not properly working when you're tracking an exercise? Does your device turns off or not track your activity correctly?
Looking forward to your reply.
Your reply is appreciated @Bluebelt, thanks for the details that were shared with me.
Seems odd that your Versa Lite is behaving in such way, can you please let me know if you're using a Fitbit original clock face on your device or a third-party one? When was the first time you experienced this situation and how many times since then? Let me share with you that the battery of our Versa Lite was designed to last 5 days, but this also depends on how frequently you use all the features of your device. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above information, please check this help article for more tips and recommendations. This article includes a restart process that will refresh the device's performance and should solve the display issue as well.
Let me know if further assistance is needed and if you have any additional questions.
