02-22-2021 05:32 - last edited on 02-22-2021 13:01 by LiliyaFitbit
When you buy a versa lite do you get the longer strap in the box. If no what is the total length of the product. I mean straps and the face of the versa. Many thanks
Best Answer02-22-2021 06:49
02-22-2021 06:49
Hi @Geegeeboo28 - The Versa Lite is no longer available in the Fitbit Store. If you order it elsewhere, you will have to check with the retailer about which bands are included. I found the following Versa Lite info on Google. You can also how to measure your wrist. Please make sure you are buying the device from an authorized retailer so it qualifies for a warranty.
02-22-2021 07:41
02-22-2021 07:41
