08-12-2021
13:43
14:16
08-12-2021
13:43
14:16
At my office suddenly I noticed that only the logo is appearing on my screen. But couldn't do anything. Tried by pressing the button. Nothing happened. Used the process form the forum by pressing for 8 sec then releasing for less than 2 sec then press again till the vibration and logo. Nothing worked. I kept it in charge LOGO stuck again. But a red light is always blinking behind.
Any HELP
Hi there, @nirakarsethy. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out. I understand where your concern is coming from.
In addition to the steps you've performed so far, please try the following:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best AnswerThank you for your kind and generic answer... I mentioned, "It cannot restart." And a red lighting is on all the time..
Best AnswerI wasted buying this from this brand. I'll help other ...
