08-27-2021
03:17
08:48
08-27-2021
03:17
08:48
Hi, my Versa screen cracked minutely and went black after I met with an accident a few months ago. Is there a solution; repair replace which I can go forth with?
08-27-2021 08:49 - edited 08-28-2023 05:22
Hi there, @SayliV. Welcome to the Community Forums. I'm sorry to hear about your Versa's screen damage.
Please note the screen cannot be replaceable. When a tracker suffers damage while under warranty, you can contact Customer Support. Discounts and replacements depend on tracker model and other factors.
However, as our warranty states, it doesn't apply to damage or defects caused by:
(a) use with non-Fitbit products
(b) accident, abuse, misuse, mishandling, flood, fire, earthquake or other external causes
(c) normal wear and tear or aging of the Product such as discoloration or stretching
(d) operating the Product:
(i) outside the permitted or intended uses described by Fitbit
(ii) not in accordance with instructions provided by Fitbit
(iii) with improper voltage or power supply.
For more information about this, you can check our warranty policy.
