09-26-2022
11:14
11:28
09-26-2022
11:14
11:28
Best Answer09-26-2022 11:29
09-26-2022 11:29
Hi there, @1ladybug. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa Lite.
If you haven't done so yet, I'd recommend trying the steps below:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
09-26-2022 11:29
Hope that helps.
