07-19-2021
15:35
16:32
07-19-2021
15:35
16:32
I have this message on my watch. I can't get past this screen. Won't turn on. Won't sync
Data Not Cleared
Sync and Try Agajn
Best Answer07-19-2021 16:32 - edited 10-08-2023 08:35
Hi there, @grantdiva. Welcome to the Community Forums. Thanks for the details shared in your post.
Please note that the error message you're receiving on your watch's screen usually appears when you've performed a factory reset without first unpairing the watch from your Fitbit account. With that being said, I'd recommend the following to solve the issue:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
