04-28-2020
15:03
12:57
DavideFitbit
04-28-2020
15:03
12:57
DavideFitbit
I got the new versa watch. However, when I set it up, all of my old info completely deletes. Even past steps.none of my info transfers over and none of it will show on the app. How can I keep my old numbers, but with the new watch? I have to show record of all my steps for insurance, so I can’t just start over.
Moderator edit: format
04-28-2020 15:43
04-28-2020 15:43
It sounds like you must have created a new account. Make sure you are logged into the same fitbit account/email that you were using before. Then add the Versa 2 to that account and all your historic data should still be there.
Try checking the fitbit.com dashboard for your old data. And you can find the email that goes with it under 'Settings'.
