12-22-2019
03:44
07:00
12-22-2019
03:44
07:00
My versa lite is not responding. I am trying to get it to sync and it won't even attempt to sync. I held button to restart it and it still isn't responding.
Hi there @softball274, welcome to the Community Forums. Thanks for the details provided and for trying to solve the syncing and screen issues on your Versa Lite prior to contacting us.
Since the restart hasn't worked, please take a look at the help article: Why isn't my Fitbit device's battery charging?
We recommend to charge your Fitbit via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. For best results, don’t leave your device plugged in on the charger longer than overnight.
Tips to better charge your Fitbit:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Keep the charging contacts on the back your device and the pins on the charging cable clean and free of debris. For more information, see: How do I clean my Fitbit device?
Also, while reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
Best AnswerThis so called best answer does not even begin to answer the original question. The question was That the versa lite will not sync or stay synced. I have been having the problem off and on since I got it in March. First it would sync back up then it got harder to get it to do so and now once you get it to sync it only does so once and then it is lost again. For the price of it they should work much longer that four months.
