03-05-2023
16:46
09:36
03-05-2023
16:46
09:36
I put my versa lite on the charger. It take a little while for it to show the start screen then won’t do anything else. It will stay on the start screen for a while. I pull it off and it won’t turn on. What can I do to fix it?
Best Answer03-10-2023 04:30 - edited 07-29-2023 03:38
@Deeannknapp Thanks for the update.
Since your Fitbit device is stuck on the Fitbit logo, please try the following steps:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
In order to attach a video, please try the following:
Best Answer03-06-2023 09:38 - edited 03-06-2024 07:42
Hi there, @Deeannknapp. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa Lite from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer03-09-2023 13:04
03-09-2023 13:04
I have moved my charger to different outlets and it just does the same thing. It turns on only to the Fitbit logo and will stay like that for a while then turns off. When I take it off the charger and try to turn it on it will go black. I took a video not sure how to share it
