06-26-2020
04:45
18:31
06-26-2020
04:45
18:31
My versa lite won’t turn on even if I keep it to charge. I had not been using it for a month and it had run out of charge but now even if I plug it in for an hour it won’t turn on. The Fitbit logo appears and then goes away. Pls help, thanks
Best Answer06-26-2020 18:32
06-26-2020 18:32
Hi there @PranavGayatri, welcome to the Community Forums. Thanks for the details provided in your post about your Versa Lite that is not charging and for taking the time to try fixing the issue prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
Let me know on the outcome, I'll be around.
Best Answer06-26-2020 23:13
06-26-2020 23:13
I did what you suggested but the problem is still there. It keeps showing the Fitbit logo and then a blank screen. I’ve checked the charger and it’s working, I tried booting it up but it’s not turning on.
Best Answer06-27-2020 03:07
06-27-2020 03:07
Hello there @PranavGayatri. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I'll be around if you have any questions present.
Best Answer09-15-2020 01:22
09-15-2020 01:22
Hi, I have been facing the same problem and have followed the steps as suggested by you. The device is the Fitbit Versa Lite too. Please advise.
Best Answer09-15-2020 07:46
09-15-2020 07:46
Hi there @Sonikadamania, welcome on board. Thanks for following the tips and recommendations I've provided in this thread to solve the issue with your Versa Lite screen. I understand how you must be feeling.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best Answer09-15-2020 08:19
09-15-2020 08:19
There seems to be an issue here with Versa software judging by the threads being created (Not charging, won't turn on etc.) and no amount of "have you rebooted it?" "have you cleaned the connections?" "have you checked the charging cradle" etc. is going to cure it.
Can we get some technical explanation out amongst the community please?
09-15-2020 09:27
09-15-2020 09:27
thanks, looking forward to it.
Best Answer09-15-2020 23:15
09-15-2020 23:15
Hi @MarreFitbit so I connected the cradle and watch on my laptop and it started. it wasn't connecting to the app, so I did a factory reset on the watch but now it is not being detected by any Fitbit app, I tried it on Windows OS app, iOS, and Android - all three.
Also, the watch was not in use for three months before this. Please let me know what should I do?
Best Answer11-01-2020 11:51
11-01-2020 11:51
I bought my Versa Lite in July. It won't turn on. I have tried several times to charge it. After I do I see the Fitbit logo but it won't do anything else. I would like a replacement, please.
Best Answer11-23-2020 09:36
11-23-2020 09:36
I cannot get my versa lite to switch on too. It is fully charged and occasionally when I plug it into the charger the logo appears, sometime on and off. Sometimes it shows the clock face and sometimes it is a blank screen. I cannot sync it to the app.as the app cannot find it as it is switched off.
