07-01-2022
05:34
07:52
07-01-2022
05:34
07:52
I have a Versa 2 that won't turn on this morning
I have tried to hold in the power button for 10sec and longer but still nothing.
07-01-2022 07:54 - edited 03-25-2024 07:34
Hi there, @VijayDaya. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out. I understand where your concern is coming from.
In addition to the steps you've done, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa Lite from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
07-01-2022 06:33
07-01-2022 06:33
Hi @VijayDaya - try recharging the watch and make sure it doesn't get hot if you used it in water recently.
Also make sure you have the correct charger, just in case you had a Versa, and that the power source is working, you can always try plugging into a PC port.
07-01-2022 07:31
07-01-2022 07:31
Hi @guy
It was my mistake, I don't have a Versa 2 it is a Versa Lite.
I have tried charging it on a laptop and still not working.
I only have one watch so I cannot try another charger/cradle
07-01-2022 08:33
07-01-2022 08:33
Hi.
I tried all of the above and nothing. The watch is still blank - not powering up at all.
07-02-2022 05:50 - edited 11-16-2023 04:24
@VijayDaya I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
