04-14-2020 23:32
04-14-2020 23:32
Good Day
My fitbit Versa Lite "froze" and lost all connections with my phone
I have done a factory reset on the watch, but have difficulty now setting up the watch again from the app? Any suggestions?
Best Answer04-14-2020 23:48 - edited 04-14-2020 23:49
Hi @cornelsteyn8003, welcome to the community.
Can you try going into you phones Bluetooth settings/menu and make sure that the Versa Lite is unpaired/forgotten from there, then go back into the Fitbit app app and try the set up process again.
Best Answer04-14-2020 23:51
04-14-2020 23:51
Best Answer04-15-2020 00:14 - edited 04-15-2020 00:15
The idea was to start the set up process again from the start, as sometimes after the factory reset the Bluetooth pairing remains (in the phones settings) and causes set up issues. I think from your initial post and the fact that you did a factory reset, this is where you are having problems? When you go into the Fitbit app and tap "set up device" it should re-establish the Bluetooth connection and start the set up process again.
So you would unpair from the phones settings - open the Fitbit app on your phone - tap profile picture - set up device - follow the set up instructions and set it up again.
Best Answer04-15-2020 00:16
04-15-2020 00:16
Best Answer04-18-2020 00:47
04-18-2020 00:47
Not working! I have re installed the app again and even tried registering with another email address... Updating firmware stops after a while... Was updating yesterday and it took all day to reach 29% then failed anyway!!
Best Answer04-18-2020 02:35
04-18-2020 02:35
I can only find the following troubleshooting steps (below) from this help article, although I believe you have already tried these steps. If you have, I would advise you to proceed with contacting customer support (here).
UPDATE FAILED OVER BLUETOOTH
If you have trouble updating your watch over Bluetooth, try these steps to resolve the problem:
If the update fails, restart your phone and retry the update.
If you still have trouble updating your watch, contact Customer Support
