01-12-2019 21:00
01-12-2019 21:00
I had entered my pin incorrectly more than 10 times so my versa locked. I tried going through settings but everytime I tried to reset pin it told me an error has occurred.
I removed he versa from my devices now it won’t allow me to connect to it again as the device is still locked.
Ive tried restarting the versa but still won’t work. I can’t use my Versa at all now
Best Answer01-13-2019 02:14
01-13-2019 02:14
Try a factory reset.
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
01-13-2019 02:14
01-13-2019 02:14
