11-06-2018 07:39
11-06-2018 07:39
Bpm- Null
Calories 0
Steps 0
But the app is showing all correct information. Tried turning it on and off.
Best Answer11-06-2018 09:46
11-06-2018 09:46
Welcome to Fitbit.
Best Answer11-06-2018 11:15
11-06-2018 11:15
@Ashleydain Try rebooting Versa several times in a row by holding left and bottom right button at the same time. If this doesn't help, perform hard/factory reset (restoring to factory defaults). If you're performing factory reset, make sure to sync your tracker first as the hard reset will wipe your versa .
11:12
07:12
11-07-2018
11:12
07:12
Hey @Ashleydain, let me give you a warm welcome to the Community! If restarting the Versa as @Marrrmaduke suggested you didn't work or the Factory reset, I'd like you to try to set up your Versa a new device. Take a look at the instructions in this help article to do so.
@GreginJaxFL, I hope you are doin' fine! Let me know if you have questions or comments.
Keep me updated!
