I am unable to add credit cards to my wallet in the android app.
I get the information entered and, if the card is not supported, I get that message (which suggests it's connecting ok). BUT, if I enter a supported card (Chase for example) - I get the terms to accept and, as soon as I do, the app crashes and has to be restarted. I've submitted logs and such, but surely there must be something I can do. I have 3 different cards from different banks that have caused this, so it's not a specific card or carrier, I don't think.
Android 8.0.0
Samsung Note 8
Versa SE (approximately 3 weeks old)
I've tried uninstalling the fitbit app entirely and re-installing it, that didn't have any impact.
I know it's connecting with the carrier because the terms are specific to the issuing bank when they show.
What can I do?
Pretty sure that's not the case because I do get the Chase terms and conditions - it's when I accept those and it tries to move forward that it breaks and the App faults.
And, if I use a card (or presumably provider) that is not supported, I correctly get a message that they're not supported and the app doesn't fault.
