03-06-2019 06:30
03-06-2019 06:30
Hi,
Anyone else having a problem with heart rate monitor today? My resting heart rate is usually 76 or 77. Today it has had me at at peak zone all day and it says I have been active for 338 minutes (I haven't!!!)
Current heart rate is 167bpm (which it isn't).
I have reset the watch, turned off my phone - and now I'm fresh out of ideas!
Thanks,
Susan.
03-06-2019 09:38
03-06-2019 09:38
Hi Susan, have you already tried to restart your Versa mutiple times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons? Sometimes this needs to be done 4 to 5 times before the problem is solved. Good luck!!
03-06-2019 12:22 - edited 03-06-2019 19:19
I have the exact same issue and I have done the "reset device dance" at least a dozen times. It does not work for me. I use it with my Samsung Galaxy S7 Edge. Hey Fitbit! Are you going to fix this or replace my Versa before my warranty period expires?
03-06-2019 14:38
03-06-2019 14:38
Same type of issue as well. Told need to wait to software update. Not able to provide a time frame. Told they are aware there is an issue.
Just wonder if it is ALL versa’s or just faulty ones.
03-06-2019 14:45
03-06-2019 14:45
Hi, unfortunately I have to mention that I do not have any problems at all with my Versa, so it seems to be limited by Versa's from a certain production line.
03-06-2019 14:52
03-06-2019 14:52
03-06-2019 14:59
03-06-2019 14:59
Hi, Sorry that my Versa is not having any problems at all, but what I do know is that Fitbit and iPhones are, to say it neatly, not an happy marriage. Users with an iPhone report more of these kind of problems than Android users and I use an Android device.
03-06-2019 15:02
03-06-2019 15:02
03-06-2019 15:03
03-06-2019 15:03
A couple of days after mine did this it died.
03-06-2019 15:04
03-06-2019 15:04
You're very welcome, that why we are around to help users with problems.
03-06-2019 16:13
03-06-2019 16:13
Yes, I’m having this same issue today, and my battery is draining more quickly than usual.
03-06-2019 20:03
03-06-2019 20:03
My experience, In a couple of days your battery won't charge at all.
