03-11-2020 23:59
03-11-2020 23:59
My Versa screen is not starting.
last I checked my versa was yesterday night. I woke up today morning to a dead screen.
The versa is syncing with the app, I am getting notifications and the versa vibrates but nothing comes-up on the screen- The screen is complete black...
Things I have done so far
1. I have tried to restart my watch - Long hold Left/back button (This does not work)
2. Factory reset- Long hold all three buttons (Nothing comes up on the screen)
3. Tried charging it- Nothing comes up on the screen (no % charging, although the device charges as I can check in the app).
03-12-2020 01:34
03-12-2020 01:34
Hi @Guy0607 I think contacting Support would be your best option. Hopefully they can help you.
Helen | Western Australia
Best Answer03-12-2020 08:20
03-12-2020 08:20
Thanks! have contacted support waiting to hear back from them.
Best Answer03-12-2020 08:33
03-12-2020 08:33
I have the same problem contacted the support team who ask me to do a factory reset holding the three buttons down etc. This did not solve the problem and waiting for more advice
Best Answer03-12-2020 08:41
03-12-2020 08:41
I have/had basically the same issue. Tried all of the same things to restart/reboot. None of it worked. Contacted customer service was told my device was not working to product standards, sent me a coupon for a new device.
Purchased in June 2018.
If you don't mind, would appreciate hearing what customer service told you to do.
Thank you.
Best Answer03-12-2020 09:05
03-12-2020 09:05
Hi just heard back from the support team I was offered a replacement as it was still under the limited warranty brought June 2029 or a voucher for 50% off another Fitbit product.
I have asked for a replacement. I find the support team were fast and very efficient
Best Answer03-12-2020 09:46
03-12-2020 09:46
