05-10-2025
11:34
07:40
MarioSFitbit
05-10-2025
11:34
07:40
MarioSFitbit
My versa shows less mileage than my treadmill so I wasn't sure which was accurate but recently I did a trail walk that was marked for mileage and my fitbit showed significantly less distance. I also walked another tike with a friend and her apple watch also showed more than my fitbit. How do I fix this?
Moderator edit - updated subject for clarity
05-14-2025 16:39
05-14-2025 16:39
@Lslp1999 , A warm welcome to the Community! Thank you for your message.
Where do you have your hands/ arms while on the treadmill?
If they are holding the guard or without movement, this could explain the issue you are having. The Versa will recognize your steps when you move your wrist/arms. So if they are holding the guard rail, or on the machine the steps might not be recognized so that the distance will also be lower as the one measured by the treadmill.
Try having your arms moving while on the treadmill to verify if there is any difference.
Best Answer05-14-2025 16:54
05-14-2025 16:54
05-15-2025 09:52
05-15-2025 09:52
@Lslp1999 , thank you for your reply and confirmation.
Just to confirm: when this happens while outside, does it happens when you record an activity or it happens when you are tracking your daily stats (normal wearing) .
If this only happens when you record an activity:
- does this appear with every activity or in one in particular?
- Does this happen when you start the recording yourself or when the activity is automatically detected?
Best Answer05-16-2025 10:20
05-16-2025 10:20
It is when I select "walk" under exercise...it does not seem to automatically detect my activity anymore either.
05-18-2025 15:50
05-18-2025 15:50
@Lslp1999 , Thank you for your reply and further information.
In this case, contact support.
Fill out the form. You will then be recommended some help articles.
You will then be able to choose how to contact support.
