Has anyone experienced a problem with their watch face after the Firmware update?
It seems the Firmware update fails to properly close the running app before doing the update.
A temporary workaround solution if this is case [and you remember next time] is to swipe up your watch face to get to the the "Today" app, before initiating the Firmware update. This will ensure you clock face will get closed properly.
I hope that Fitbit will correct the Firmware update process for the next update.
It could also be that the Firmware update wipes the application directory space, meaning the app loses its data and continuity on the restart of the watch.
It would be good that the Firmware update keeps existing apps directories and closes them properly before commencing the update.
