01-04-2019 03:44
01-04-2019 03:44
When I log my water intake on my Versa it seems to log correctly however sometimes it will sync with my phone and jump to insane numbers like 52,000ml total. When I go into the details on my phone app it says the logs are 14,700 or so. I know I have logged 500ml correctly throughout the day however these do not show up in the summary either.
01-08-2019 04:21
01-08-2019 04:21
I suspect you are seeing the same problem as I am. For some reason, on occasion something in the water logging process is seeing an entry for (say) 200 ml and instead processing it as 200 US fluid ounces. I've seen rogue massive entries regularly myself, and finally confirmed that was the issue this morning. (See https://community.fitbit.com/t5/Versa/New-Water-Log-not-Syncing-amp-Other-Qs/m-p/3180064/highlight/t...)
The only workaround I've found so far is to delete and replace or edit the rogue entries.If you can't remember what you entered, if you multiply the huge incorrect number by 0.033814 you should get roughly what the original entry was. (So 14,700*0.033814 comes out as 497 or so - it was originally a 500ml entry).
Definitely a bug somewhere.
01-04-2019 15:40
01-04-2019 15:40
@MamaBee87 You can try re-installing Fitbit mobile app and rebooting Versa by pressing and holding the left and bottom right buttons until Fitbit logo flashes, but water logging has been buggy. Let's hope it will get addressed with an update soon.
01-05-2019 17:37
01-05-2019 17:37
I am also experiencing this same problem. It's not syncing properly.
01-05-2019 19:14
01-05-2019 19:14
@lyssfitz you mean you are getting weird numbers or it does not sync your water at all?
01-08-2019 03:22
01-08-2019 03:22
I had the same thing happen a few times.
I wanted to add my first water for today on my versa and it's already at 7393 ml.
01-08-2019 03:26
01-08-2019 03:26
Best Answer01-08-2019 04:21
01-08-2019 04:21
01-09-2019 17:26
01-09-2019 17:26
I also have a problem with logging water, but a different twist on that.
Since I'm using in fl oz I have no conversion inaccuracies. Instead, when I log water via Versa the phone app does not sync it. It syncs everyevery else (hr, calories, steps, etc) but the water the was added via the watch. The watch however sees the water added via the app.
The funkiest part - it sometimes works fine, someone's works with massive delays, and sometimes - not at all.
01-09-2019 18:15
01-09-2019 18:15
@hachaduryan have you tried syncing the tracker and then talking on the water tile in the Fitbit mobile app to get into details? It refreshes this way for me ...
01-09-2019 18:26
01-09-2019 18:26
01-09-2019 18:30
01-09-2019 18:30
@hachaduryan it seems to be a bug. Sometimes one has to wait till several syncs complete to get the info to the app and back to Versa. The common tricks are: put on the charger (Versa needs to be well-fed) and wait several hours and let it sync, or uninstall and reinstall Fitbit app.
01-09-2019 18:41
01-09-2019 18:41
01-17-2019 14:15
01-17-2019 14:15
I have the same problem and came here to find a solution!
Best Answer01-17-2019 14:32
01-17-2019 14:32
@Jorena1986 Uninstall Fitbit app, reboot your phone, reboot your Versa (press and hold the left and bottom right buttons until Fitbit logo flashes). Install Fitbit app. Sync your Tracker several times. Wait for Today app to update on your Versa. Sync again and try water logging.
01-22-2019 12:22
01-22-2019 12:22
My first post here and apologies if I missed my answer... My Versa is new to me - less than 2 weeks and am loving it...
I noticed yesterday that 9966.31 oz of water was logged... I think I'd no longer be here...
Is there any way to delete data on a day where it gets inputted wrong...? Otherwise it skews everything - showing I have a daily average of 1424 oz...
<ho hum>
Best Answer01-22-2019 13:14
01-22-2019 13:14
@JJMcFarlane you can do it in the Fitbit mobile app. Open it, tap on water tile, scroll down to the day that interests you, tap and edit the logs. You can delete, change or add new ones.
01-22-2019 13:22
01-22-2019 13:22
Best Answer01-22-2019 13:40
01-22-2019 13:40
@Jorena1986 it might be delayed. In case of Fitbit app, you might have to tap on the water tile to go level down, and it refreshes.
01-22-2019 13:44
01-22-2019 13:44
Best Answer01-22-2019 18:29
01-22-2019 18:29
