Versa Won't Sync
Hello,
My Versa battery died two days ago. Now that it is charged again it is refusing to sync. I have tried some of the suggestions on here, disconnecting and reconnecting the Bluetooth, removing and re-installing the device in the app, it is now frozen in the re-installation, saying it has found the tracker and it is trying to connect. Any advice would be appreciated.
2 REPLIES 2
Have you restarted your Versa several times? If not, do that and then try setting up again.
Restart your tracker
Community Council Member
Helen | Western Australia
Great to see new faces @JCGooch and @NellyG thanks for stopping by.
I appreciate all the efforts in trying to fix this and would like to know if you keep having syncing issues? If you do, I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
Let me know the outcome. Man Happy
