09-21-2018
12:09
06:57
AlejandraFitbit
09-21-2018
12:09
06:57
AlejandraFitbit
Hi,
My Fitbit randomly turned off today, was in my pocket at work and had 50% battery left. It’s only 1 week old. Charging or restarting is not working and my app can’t find my Fitbit to sync to... any other suggestions?
Thanks
Best Answer09-21-2018 20:36
09-21-2018 20:36
Try a factory reset (settings app on the watch and scroll down to About). If that doesnt fix it you will need to return it to the store you bought it from or contact Support (link in my signature)
Helen | Western Australia
09-23-2018
06:58
08:00
09-23-2018
06:58
08:00
Welcome to the Forums @EmilyTracy and @NellyG thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and would like to know if the instructions provided by our friend worked? Were you able to turn on your watch?
Hope to hear from you soon. ![]()
