Versa display issues
Versa has a linear spectrum on screen and not showing time, text or in coming calls.
4 REPLIES 4
The first thing to try when a fitbit misbehaves is a restart using the following procedure:
  1. Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
  2. Let go of the buttons.
  3. If your Fitbit Blaze, Fitbit Ionic, or Fitbit Versa doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
It does no harm and can sort out all sorts of issues. If that doesn't help then it's probably best to contact customer support via: contact.fitbit.com
Welcome to the Forums @Nnl and @SteveH thanks for stopping by.
I would like to know if the instructions provided by our friend worked? Are you still having issues with your Versa display?
Hope to hear from you soon. Cat Happy
Yes I am. Just got a text message and noticed the lines on the display before seeing the message
Thanks for the update @Nnl.
Upon checking with our support team, I was told that you have already created a case with them. I think this is great, they will be glad to help you out and provide you with a solution.
Let me know if you need anything else. Smiley Happy
