08-09-2023 04:16
08-09-2023 04:16
I bought a used Versa recently but it ionly has a large band attached. I want to replace it with a small band.
I can't find a compatible band. Do all Versa model bands fit?
08-09-2023 06:22
08-09-2023 06:22
Thanks for your reply. Will try Amazon.
Can always return if doesn't fit.
Best Answer08-09-2023 05:00
08-09-2023 05:00
Hi @LingoLol Unfortunately not all Versa bands are the same. So you would need to check the model number is correct. If fitbit don't have one (see THIS link and scroll down to Accessories), then try on Amazon.
Helen | Western Australia
08-09-2023 06:22
08-09-2023 06:22
