08-06-2023
12:09
11:45
08-06-2023
12:09
11:45
My versa 2 screen is black. How do I get it to turn back on? It is sending notifications and is fully charged.
08-07-2023 11:48
08-07-2023 11:48
Hi there, @LynnEmma. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As @Talahthas has recommended, please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
08-07-2023 04:05
08-07-2023 04:05
Welcome to the Fitbit community, @LynnEmma!
Sad to hear that your Versa 2 isn't working as expected. I would try to see if restarting it will fix the issue you've mentioned above. To do so, please hold your Versa 2's button for around 10 seconds until you'll hopefully see the Fitbit logo on it's display.
If that won't work for you, your device may be defective. In that case I'd suggest to contact Fitbit support for further assistance:
I'll keep my fingers crossed.
Best Answer08-07-2023 11:48
08-07-2023 11:48
08-08-2023 07:53
08-08-2023 07:53
08-08-2023 08:54
08-08-2023 08:54
This seems to be happening to a lot of us the past few hours to a lot of us the past 48 hours what is going on?
08-08-2023 09:36
08-08-2023 09:36
Thanks for the suggestion. I can’t access the screen to change anything. I did reboot a few times by holding the side button in until I felt vibrations and I did recharge it. Again, I can’t see if there were responses on the black screen.
