There seems to be optional bands for the black and silver colored Versa however, the rose gold has no band options for evening wear. Has anyone located other band options for the rose gold. Otherwise, I will not likely purchase.
just did a search on Amazon... looked for "fitbit versa rose gold bands" and some nice ones came up... some had rhinestones, metal link and clasps.
Give it a look and see
@nurs @Jamaicangirl81 Welcome to the Fitbit Community! I hope you're doing well! All Versa wristbands are interchangeable so you can purchase any band from the Fitbit store and wear it with the Versa you have/want to purchase. Like @Jamaicangirl81 mentioned there are also third party accessories that you can check but make sure you read the reviews as they aren't made by Fitbit so I can't comment on their quality or materials.
Let me know how it goes!
EBay or Amazon usually has decent selections, and they're much cheaper than Fitbit. Usually the bands on Amazon or EBay will run you $5-$10.
one cruise ship at a time!
@DramaQueenDiva hope you are doing great! Have you purchased any of these bands? What has been your experience with them? Could you share some pictures if you have them?
I look forward to your reply!
I had one from EBay for my Alta HR, but one side of the bracelet broke and won't connect to the device anymore. It was mesh metal with rhinestones on it, specifically picked out for a cruise I was about to take that time.
Now I'm looking for a similar band for my Ionic and Alta HR, once again, for a cruise. The rhinestone band cost me $5.
I also used to get Flex bands from them too....I got a pack of 5 for $5. They came in silver, purple, and black with white polka dots. I forgot what the other colors were. Never had a problem with the Flex bands.
Best AnswerI have tried 3rd party and they do not fit. I think Fitbit need a stainless steel option for the rose gold versa for an evening look. It seems odd that you can dress up the black and silver versa's and not the rose gold.
