11-12-2020
04:54
14:09
RicardoFitbit
11-12-2020
04:54
14:09
RicardoFitbit
My fitbit versa is very slow to response and the battery is draining so fast. It keeps reset itself also i couldn't sync with my phone anymore. I tried to do factory reset 3 times but nothing happened.
11-12-2020
16:25
16:46
RicardoFitbit
11-12-2020
16:25
16:46
RicardoFitbit
My versa working when plugged in. When i removed it, it’s showing fitbit logo only and couldn’t do anything with it. Try to reset, factory reset, update everything but still.
Best Answer11-13-2020 14:07
11-13-2020 14:07
Hi @Mickeymild, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. Let me share with you that the battery of our Fitbit Versa was designed to last 5 days but this also depends on how frequently you use all the features of your device. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above information, please check this help article for more tips and recommendations. This article includes a restart process that will refresh the device's performance and should fix the connection issues as well.
Let me know if further assistance is needed and if you have any additional questions.
Best Answer11-13-2020 14:17
11-13-2020 14:17
