05-02-2019 23:13
05-02-2019 23:13
Hi
Anyone having problems with battery drain? My battery used to last 3 days minimum, all of a sudden I am having to charge every 2 days. Not changed anything on watch and actually have been doing less exercise, so wouldn't expect it to be running low quicker!
Any advice appreciated.
Thanks
05-02-2019 23:20
05-02-2019 23:20
Hi @Purplepepper Try restarting it several times and see if that helps with the battery life. Life of a battery does decline with age. How old is your Versa?
Helen | Western Australia
Best Answer05-03-2019 03:46
05-03-2019 03:46
I've had the same thing happen to me. I've owned my Versa for almost a year, and suddenly with the last Fitbit update, I now have to charge my Versa twice a day. I have tried restarting several times over the course of the last week, but I refuse to turn off the heart rate sensor and all of the other features that were the whole reason for buying a Versa. Does anyone know how long the battery is supposed to last in a Versa before you are forced to buy a brand new one?
Best Answer05-03-2019 04:55
05-03-2019 04:55
This is happening to mine and I have only had my Versa for 2 months maybe
Best Answer05-03-2019 06:01
05-03-2019 06:01
I will give the restart a go, only had it about a year, I don't believe for the cost of the watch that this should be happening already!
Also would have thought it would be a slow decline, this has gone from lasting minimum of 3 days to overnight only now lasting 2 days
Best Answer05-03-2019 06:06
05-03-2019 06:06
Oh I've probably "restarted" my Versa 50 times in the last week.
And yes, last Friday it was fine and I went with my normal charging routine and since then, I get less than 24 hours before I need to charge again. For example, I am sitting in an office and at 7 am I was at 97%. It is now 2 hours later with minimum activity and I am at 86%.
