05-21-2019
19:32
06:17
JuanJoFitbit
05-21-2019
19:32
06:17
JuanJoFitbit
I got my Fitbit versa not even 6 months ago and now it won't hold a charge for more than 8 hours maximum! I'm a nurse and I love tracking my steps and seeing how many miles I walk in a shift but my battery won't last my 12 hour shift. Is this something normal for a Fitbit versa? I love my watch but there is no point in wearing it if the battery doesn't even last 8 hours. Thank you!
05-21-2019 20:13
05-21-2019 20:13
Welcome to the forums!
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Best Charging Practices
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
Best Answer05-22-2019 06:15
05-22-2019 06:15
@tarynleigj Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since its battery is not lasting as long as it should.
I'd like to know if the issue persists or if it got resolved after following the steps that shared @WendyB.
As a side note, I'd like to share this help article which provides tips to improve the battery life of your Versa.
Keep @WendyB and me posted on the outcome! ![]()
05-22-2019 07:19
05-22-2019 07:19
@JuanJoFitbitmy versa is doing the same thing. It was fine until Monday. Came to work with it at 89% and it was at 8% that evening. This has never happened. Normally get 4 to 5 days out of a charge. I charged it Monday night. It was at 99% when I left for work at 6:30am. It died at 3pm. I charged it last night and it was only at 49% when I woke up. I even cleaned the contacts before charging it. Now at 9am it is at 23%.
This is very frustrating. And frankly a waste of time.
My friend has his set up through an android and he is not experiencing the problem. Mine is through an iOS and I am having the issue. My dad even had the same issue Monday with his.
Please give a better solution that cleaning the contacts and resetting as that is not working. I have not changed anything on my end and I've only had it for 5 months. I think it is due to an update that went out within the last week.
05-23-2019 05:35
05-23-2019 05:35
Thank you I've tried all of those and nothing helps it charges great hit won't keep the charge its the charger it came with and I've cleaned it multiple times thank you!
05-23-2019 05:36
05-23-2019 05:36
I tried those but they didn't work.. thank you.
05-23-2019 07:47
05-23-2019 07:47
@tarynleigjI did a factory reset last night and I still am having the same problems today. It was fully charged when I left for work and now is at 70%.
This is ridiculous. All in a week.
05-23-2019 08:12
05-23-2019 08:12
Have you gotten any response that has helped you with this issue? I am having the exact same problem and it started on Monday as well. Mine won't even last through the night now. I went to bed with 75% battery (after having to charge it twice during the day in order to use it) and it was dead when I got up less than 6 hours later. I have done all the things that were suggested and nothing is working.
Best Answer05-23-2019 09:32
05-23-2019 09:32
@kgiffordI have had zero response from FITBIT on this. Frankly, I'm fed up with it.
Best Answer05-23-2019 10:00
05-23-2019 10:00
@tarynleigj @kgifford So I chatted with someone who is supposed to be sending me an email to test my battery.
I let her know that I thought this was ridiculous, how everyone is seemingly having the same issue that occurred at the same time, but nothing is being done in the same mass way to fix it.
If the battery test works, I will respond. I'm not hopeful at this point.
Best Answer05-23-2019 10:05
05-23-2019 10:05
So I called them. They want me to do the following: charge it to 100% . Let it run down to 0 while using it like i normally do until the battery fully drains. during the drain period I’m to sync it frequently. Apparently they can monitor it that way. Also, I made sure I have a Fitbit clock face and removed all that might drain the battery faster like all day sync, which I never had to
start with and turn off notifications. Then I need to call them back. I’ll
let you know. I still think this is because of some update they did as it happened fast and I hadn’t changed anything I was doing.
Best Answer05-23-2019 11:46
05-23-2019 11:46
They told me the same thing. Sent me an email with instructions. But its still crazy in my opinion.
Best Answer05-29-2019 19:54
05-29-2019 19:54
Hello @tarynleigj , @Duracious18 and @kgifford, it's nice to see you again in our Community Forums! I am sorry for the delayed response.
@tarynleigj thank you for your efforts to resolve the issue. Since the issue persists, I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@Duracious18 and @kgifford thank you for joining the conversation and sharing your experience. I totally understand how you are feeling and appreciate your efforts to resolve this. I am glad to know that you're working with our Support team regarding this matter. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
Best Answer05-29-2019 21:47
05-29-2019 21:47
Mine just ran out at 8pm today, I’ve been having to charge it 2x a day for the past 2 days. The screen started glitching (numbers were lines and just all sorts of mess) and now it just seems dead 😞
