06-16-2019
11:17
07:55
JuanJoFitbit
06-16-2019
11:17
07:55
JuanJoFitbit
My original Versa would not hold a charge for more than 5 hours. My replacement lasts for approx 2 days. Is this good bad or average?
@JWCAMPBELL welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since its battery is not lasting as long as it should.
I'd like you to visit this help article and follow the tips listed. These steps are helpful in order to improve the battery life of your watch.
Keep me posted on the outcome! ![]()
Best AnswerJuan, I did these as per instructions when my original fitbit battery failed to hold its charge.The replacement battery is better and I have followed the previous instructions. But still only lasts for two days.
Best AnswerI got my Versa for Christmas & it has worked beautifully unil about a month ago. The red light on the back came on & wouldn't go off. It DRAINED the battery soooo fast. So, I reset & powered on & off several times until the red light finally went off & it has presumably been working like it should but now the battery wont last 2 days. I have followed all the battery saving options & changed setti gts to several configurations but nothing is working.
Best AnswerOriginally right out of the box I was getting 4 days with the settings I had. Then the red light thing happened & not it's not even lasting 2 after turning all the things off.
Best AnswerI had done all those things previously and still the battery life lasts for two days.
