04-23-2018
12:02
18:53
EdsonFitbit
04-23-2018
12:02
18:53
EdsonFitbit
Yesterday i charged my Fitbit Versa to 100%, used the connected GPS for about an hour, then it was just normal use all night, went to bed and woke up this morning and went to check the screen and it was black. I plugged it in and it was completely dead. Is this a fluke or should I go return it to get a new one?
Moderator edit: added label
04-23-2018 12:23
04-23-2018 12:23
If you can not restart it then you have little choice except to return.
Best Answer04-23-2018 13:59 - edited 04-23-2018 14:05
Edit: it finally restarted, should i consider returning it if it continues?
It fully charged but seems like it won’t restart, is this a clue to what is to come?
