01-20-2022
01:39
08:13
01-20-2022
01:39
08:13
The battery of my versa battery does not last a day
Hi there, @salvy2019. Thanks for stopping by in the Community Forums.
As you may know, your Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Hope that helps.
