10-09-2020
08:17
11:07
10-09-2020
08:17
11:07
Hi Maria, I have done all the above and still my battery last 2 hours.
I have a versa watch.
please help
how long does a versa watch last?
thank you
Hi there @Nelldi, thanks for stopping by in the Community Forums. I'm sorry to hear that your Versa's battery is draining quickly. Thanks for following the tips and recommendations I've provided in the previous post.
Because battery life is affected by use and other settings, actual results may vary. That being said, the battery of your watch should last 4+ days.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I've moved your post to the Other Versa Smartwatches board to for organization purposes.
I'll be around if you have any questions present.
Hi there @Nelldi, thanks for getting back and for the update. I'm glad to hear that turning Screen Wake to manual has helped you.
