10-20-2020
07:21
12:35
10-20-2020
07:21
12:35
Fitbit just replaced my Versa due to an issue with the battery charger- I’ve had the new Versa for about 2 weeks. The first week the battery lasted about 3 days and now it lasts only a day of that. Any ideas?
thanks
10-20-2020 12:40 - edited 10-30-2020 07:03
Hi there @Jerrie.ann16, welcome to the Community Forums. I'm sorry to hear that your Versa's battery life is not lasting as expected. Thanks for the details provided in your post, I'll be glad to continue helping you.
As you may know, your Versa battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
I'm looking forward to your response.
10-21-2020 15:36
10-21-2020 15:36
10-22-2020 06:41 - edited 04-21-2024 08:17
Hi there @Jerrie.ann16, thanks for getting back and for the update.
I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
10-22-2020 08:04
10-22-2020 08:04
I’m having the exact same issue with battery life. Not to mention the screen scrambles and quite often wont even turn on. I’ve changed no settings and use no gps or anything. Haven’t even had the watch for a year....
