My Versa is not yet one year old and the battery now lasts only two days. I have not changed any settings that would drain the battery.
@GrapeApe2728 If it does not help, please perform a factory reset (restoring tracker to factory defaults). You might have to perform it several times. I saw a few cases that after 2nd or 3rd factory reset it righted itself. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. If you're unable to use the screen, please try performing the factory reset using the buttons:
After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app. You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Best Answer@GrapeApe2728 Have you installed any 3rd party apps or clockfaces? Have you rebooted your tracker several times?
Best AnswerI’ve only installed clocks on the app that are free. It’s not been a problem before. Yes, I’ve restarted it several times. I’ve uninstalled the clock faces. I’ll see if that helps. Thank you
Best Answer@GrapeApe2728 If it does not help, please perform a factory reset (restoring tracker to factory defaults). You might have to perform it several times. I saw a few cases that after 2nd or 3rd factory reset it righted itself. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. If you're unable to use the screen, please try performing the factory reset using the buttons:
Best Answer@Erkka It shouldn't. If you do not have any 3rd party clockfaces/apps installed, try performing a factory reset.
Best AnswerThank you I will perform a factory reset.
Best Answer@Erkka Yes, the all-time display drains a lot, but still you should get more than 2 days. Please see my post above.
@GrapeApe2728 Let me know how it went. 😄
Best AnswerThanks I’ve never had it on all time display.
Best AnswerI will let you know thanks. Just finished setting it up after factory reset, I had not altered any settings before this happened so I’m hoping this helps. I only have two Fitbit clock faces, no third party, we’ll see!
Best AnswerHasn’t gone well. Battery died in the middle of the night last night, and went down 40% in 10 hours today. I’ll try again, then contact customer support. Thanks for your help.
Best AnswerWell it’s worse now lol. I’ve done a factory reset twice and the battery lasts about 19 hours. I’ll contact customer service.
