05-23-2018
06:54
04:43
AlejandraFitbit
05-23-2018
06:54
04:43
AlejandraFitbit
Has anyone else experienced this issue: the battery is charged almost fully, let's say between 80-100%, and then suddenly you notice the watch has turned itself off and shows 0% when trying to reboot it.
This has happened a few times to me over the last few weeks now and it's starting to become annoying. This does not seem to be not a case of battery drain, I don't notice any drops in % it just suddenly switches off. When this doesn't happen the device easily lasts 4 days, with the exact same usage. So I cannot tell what is causing this.
Looking for some input before I contact support about this.
08-23-2019 16:13
08-23-2019 16:13
It will go according to UK Law - it's as simple as that (and if necessary.....I'll fight all the way).
FitBit want the watch to be returned to fiddle with before they return it to me....that's an unnecessary inconvenience on a product which isn't fit for purpose (in fact it's a dangerous product with the heat that's being produced from the battery). It's also a product which is less than 6 months old (in fact the current faulty one is now just 3 days old!)
There's no question of whether I get the refund or not....
Best Answer08-23-2019 16:22 - last edited on 09-05-2019 12:32 by LiliyaFitbit
True that
Best Answer08-23-2019 16:43
08-23-2019 16:43
Aaaaand Amazon are taking it back for a full refund 🙂
They're also looking into temporarily suspending the Versa on their UK site for safety reasons
That's a result in my book 🙂
Best Answer08-23-2019 16:50 - last edited on 09-05-2019 12:32 by LiliyaFitbit
AWESOMNESS, you go!!!!!!! They need to address this issue of high brand
name item that appears to be a crapshoot......congrats!!!
Best Answer09-05-2019 12:28
09-05-2019 12:28
My versa is about 9 months old and dying too. I may have to return it to Costco for a replacement. It charges 100% but the next morning dead again.
Best Answer09-08-2019 21:30
09-08-2019 21:30
I am also experiencing this problem. I haven’t done anything different with the fit bit and I’m going to contact customer support as well.
Best Answer09-11-2019 08:22
09-11-2019 08:22
i had the same behavior for about 2 weeks, and then it would no longer charge at all. Support could not fix this, and I am 2 months outside my warranty, so no replacement!
Best Answer11-25-2019 15:15
11-25-2019 15:15
Hi, how long you have been using it before it was replaced?
Best Answer12-03-2019 17:35
12-03-2019 17:35
The same thing is happening to mine. Very frustrating as they aren't cheap. Mine charges okay within an hour it has dropped to 78% by say lunch time 0%. I took it into a jeweller and they can't change the battery. It seems ridiculous nothing can be done especially something simple as changing a battery. So now I'm stuck with a fitbit I can't wear
Best Answer12-03-2019 17:37
12-03-2019 17:37
The exact same thing is happening to me! Very very frustrating. And no way to put a new battery in. I don't think I'll buy another one as this is the second versa I've bought.
Best Answer12-03-2019 17:59
12-03-2019 17:59
I charged my Versa to 100% yesterday. Battery, however, completely drained out last night.
Best Answer12-03-2019 18:32 - edited 12-03-2019 18:33
Isnt it frustrating! I love my fitbit too. It seems to be happening to alot of people. Should be able to at least change the battery. My jeweller said there's is nothing they can do. I look after it and never rough. I don't think I'll purchase another fit bit as this is the second versa I've owned and the sale thing has happened. Too expensive to keep replacing them.
Best Answer12-06-2019 05:52
12-06-2019 05:52
Best Answer12-10-2019 21:09
12-10-2019 21:09
Tonight, I have joined the Versa Lite battery died club. I had my battery charged to 99% in the late morning. Twelve hours later my battery is dead. My fitbit isn't very old. Naturally, I purchased mine shortly before the first commercials for the Versa 2 came out. I did recently have a update on the watch.
Has anyone gotten a fix yet?
Best Answer12-23-2019 05:35
12-23-2019 05:35
My Versa suddenly has died. In 3 days it went from working perfectly to wouldn’t stay charged more than 9 hours to completely inoperable. It isn’t even a year old. Please do not insult me by suggesting I charge it incorrectly! Seems that is the standard response from support. How should I troubleshoot? The watch will not turn on.
Best Answer12-23-2019 09:36
12-23-2019 09:36
Best Answer12-26-2019 22:08
12-26-2019 22:08
Best Answer12-26-2019 23:20 - last edited on 02-06-2020 12:14 by LiliyaFitbit
Glad that worked out!
Best Answer12-30-2019 15:21
12-30-2019 15:21
My new Versa was functioning well until after about 6 months... hopefully it’s not a false alarm that it works only because u got a new one.. wait 6 months and see.
Best Answer01-13-2020 23:33
01-13-2020 23:33
My Fitbit Versa 2 suddenly died today while I was in the gym. I put it on the charger when I got home but it won’t charge. The charger is fine I checked it. The Versa 2 wont turn on or anything. What can I do? Where can I have it looked at?
