09-08-2020
10:29
14:28
09-08-2020
10:29
14:28
I've had my Versa for almost two years; typically I charge it before it's completely dead but 2 weeks ago was unable to do it. Now the battery won't charge. I've cleaned the contacts on the Versa and the charger with alcohol but no luck. Any suggestions?
Hi there @RogMorgen2, welcome to the Community Forums. Thanks for the details provided in your post about the difficulties you've been having to charger your Versa. I appreciate you've already taken the time to troubleshoot your watch prior to posting here, I'll be glad to continue assisting you.
If you haven't done so yet, please try the suggestions below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
