06-25-2020
05:42
06:20
06-25-2020
05:42
06:20
Versa won't turn on. Screen still black. I have changed the clock face. Tried holding back button and bottom button to force restart. An I cannot seem to contact support. HELP
06-25-2020 06:24 - edited 06-12-2024 05:06
Hi there @Cassandra2020, thanks for stopping by and for the details provided in your post. I appreciate you've taken the time to troubleshoot your Versa's screen prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
Once you've tried and checked the above steps, I suggest you to charge your Versa at least 1 hour to see if the screen turns on. If the issue persists, let me know and I will be glad to create a support case on your behalf. We're sorry for the hard time you had while reaching our Support Team, due to recent events affecting our operations, support options are limited and wait times are longer than usual.
Best Answer06-25-2020 09:46
06-25-2020 09:46
I currently have Versa on the charger to try again. But my fitbit app shows charged, the Versa is just not turning on. The green light on back is still working
06-25-2020 10:27
06-25-2020 10:27
Hello, my Versa is having the same problem. Yesterday it died and I got home and put it on the charger the screen won’t light up or show anything. I have followed all the steps you listed and have switched outlets, boxes And cords but still nothing. I reached out for help yesterday but the guy wasn’t very helpful.
Best Answer06-25-2020 11:27
06-25-2020 11:27
Okay so Versa is fully charged and still nothing. Just a black screen. The green light indicator is still flashing. But nothing else is working.
Best Answer06-25-2020 12:29 - edited 06-12-2024 05:05
Hello there @Cassandra2020 and @HaleyMcC, thanks for getting back and for the details provided in your posts. Since your Versa is still vibrating and flashing the green lights on the back, it may also be syncing as per your responses, so please try the following:
Hello @HaleyMcC. I'd like to give thanks for the feedback you've provided towards our Customer Service. Please know that we provide feedback to our team based on community posts and we are always working on improving our overall environment based on that feedback.
Best Answer06-25-2020 17:15
06-25-2020 17:15
I have already changed the clock face several times. And also have tried a restart. But I cannot click into settings on Versa because screen is black
Best Answer06-26-2020 04:53 - edited 06-12-2024 05:05
Hi @Cassandra2020. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I'll be around if you have any questions present.
Best Answer06-28-2020 20:25
06-28-2020 20:25
