01-21-2019 18:24
01-21-2019 18:24
My versa was blocked this morning after my child tried to enter the pin too many times
I tried to unblock it via my app and it kept coming up with an error, so I reset my versa, still didn't work. I uninstalled and then reinstalled the app and it still wasn't working so I took the device off my app.
Now I can't add a device again as it asks for a code and when I look at my versa it says unlock with your phone Arghhh help!!!!
Best Answer02-04-2019 01:01 - edited 02-04-2019 01:04
@KylieMC your Versa is locked because wrong code was typed 10 times. When this happens one needs to unlock Versa using the phone. You mentioned you had deleted Versa from Fitbit mobile app which means you unlinked it from you Fitbit account. You will not be able to pair it again as you will not be able to see pairing code. The only way out (beside contacting Customer Support) is performing a 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
@MichellevV Is your Versa still linked with your Fitbit account? If yes, do not remove it.
01-21-2019 20:23
01-21-2019 20:23
Try removing the credit card via the phone app.
01-21-2019 21:30
01-21-2019 21:30
Mine is doing the exact same thing I have no idea what’s wrong with it and silly me also unhooked it from my phone and now can’t get it back on
Best Answer01-21-2019 22:39
01-21-2019 22:39
It don't even see a credit card linked on the app, maybe because I removed the device from my app it automatically removed that?
Best Answer01-22-2019 01:21
01-22-2019 01:21
I would like any suggestions, as I have done exactly the same thing.
Best Answer01-22-2019 16:28 - edited 01-22-2019 16:29
I called the Helpdesk, the lady asked me to do the factory reset on the Fitbit, this also didn't work (my Fitbit wouldn't reset after trying about 10 times!) so she was stumped and had to pass it onto a tech I think, she said they will look into it and get back to me.......
Best Answer01-22-2019 17:01
01-22-2019 17:01
Best Answer01-24-2019 03:39
01-24-2019 03:39
Hi Kyle
Have you had any success with unlocking your Versa. I went back to the Ftibit Support Chat. They have given me instructions to reset but they have not worked. They said they are working on a fix and to keep an eye out for app updates. They also suggested returning the Versa to the place of purchase for a refund.
Best Answer01-24-2019 12:56
01-24-2019 12:56
Hi Michelle, no success here yet! Getting a bit frustrating now, the Fitbit is not even a month old
I have messaged Fitbit support again to see if there are any updates but sounds as though they don't actually know how to fix it?!
I wonder if an app update would help at all considering the problem for me now is that I can't connect the versa to the app as the code to connect won't show up on the Fitbit! I guess if I could actually add the Fitbit back on then an update might be helpful in unblocking it.....gah...
Best Answer01-24-2019 16:59
01-24-2019 16:59
Best Answer01-24-2019 22:07
01-24-2019 22:07
I got mine from there too, so yeah definitely let me know how you get on!
Best Answer02-03-2019 01:27
02-03-2019 01:27
Have you managed to return it to Harvey Norman yet Michelle? I am going to try and take it back tomorrow, I spoke to support again and they have no idea how to fix it at this stage and said they can't give me any timeframe so it could be ages! So i'm going to try my luck and take it back....
Best Answer02-04-2019 00:03
02-04-2019 00:03
02-04-2019 01:48
02-04-2019 01:48
Best Answer02-04-2019 01:55
02-04-2019 01:55
@MichellevV is your Versa still linked with your Fitbit account or did you delete it from Fitbit mobile app?
02-04-2019 05:01
02-04-2019 05:01
Best Answer02-04-2019 11:27
02-04-2019 11:27
Thanks for the message @Marrrmaduke, my versa would not complete a factory reset after trying many many times. I spoke to customer support a couple of times and they didn’t have a solution and couldn’t give me a timeframe for when they would have one, just said the techs were still gathering information about the issue and she didn’t know where they were at with regards to finding a solution. She said I could try and take it back to the store my husband bought it from if I wanted to.
@MichellevV oh no! I hope you can get it replaced through the company you bought it from. I also tried to drain the battery a few times and nothing working 😞 I took mine back yesterday and they replaced it straight away
Best Answer02-04-2019 11:32
02-04-2019 11:32
Hey guys, I hope you are doin' great!
@KylieMC, I appreciate you have taken the time to try to resolve this issue with your Versa, since it's blocked, and also for taking the time to contact our Support team. Let me ask you this, have you already returned it to the original retailer where you purchased it? Or did you contact our Support team for further help?
@MichellevV, among the things you have done, have you tried to set up your Versa as a new device? If you haven't, please follow the instructions in this help article: How do I set up my Fitbit device? And let me know ho wit goes.
@Sophie1995, were you able to unlock your Versa? Have you tried the instructions in the help article: How do I use the device lock on my Fitbit device?
Thanks for your help guys, @Marrrmaduke and @JohnnyRow
Keep me posted!
02-04-2019 16:00
02-04-2019 16:00
@MichellevV I see. At this point it's either factory reset or replacement device, I'm afraid. 😞
