I want to replace the buckle with a deployment clasp, anyone able to post the width of the strap at the buckle end? I know the strap at the watch end is 22mm but I am guessing it tapers at the buckle end. My Versa turns up on Sunday so I can't just measure it myself before anyone suggests that! 😂
Is there anyone out there?.... is the community dead??
Best AnswerMy strap/band that came with my watch measures 20mm at the buckle end so it doesn't taper down much. I hope this helps.
Best AnswerThank you!
Best AnswerJust got the device, the strap is 22mm at the buckle end, not 20mm as mentioned.... oh well, anyone want 2 20mm deployment clasp!!
Best AnswerIt's 22mm, not 20mm as you suggested....
